recommended fuel grade for SS?
Old Apr 11, 2004 | 02:53 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Question recommended fuel grade for SS?
Does GM recommend premium (93 octane here in TX) for the Silverado SS? Or can it be safely run on 87 octane?
On F-bodies, GM recommends premium, on my previous GMC 87 octane was fine.
Old Apr 11, 2004 | 02:55 PM
BlownChevy's Avatar
blownerator
25 Year Member
Would not run anything less than 91!!
Old Apr 11, 2004 | 02:57 PM
Detination with low octane, and the higher compression of a SS. If your on a road trip cruising, and not towing cheaper would be ok. But under strain, at least 91.
Old Apr 11, 2004 | 05:11 PM
MNC5's Avatar
The stock timing is pretty tame. I've never tried it but you should be able to run regular as long as your not jumping on it. Try a half tank of 87 and if it rattles add some 92
Old Apr 11, 2004 | 06:44 PM
mwalls54's Avatar
Need More N2O Mod
i have tried 87. not on purpose. my dad thought he would be nice and fill it up for me. any way i had some light valve chatter that was cured with some nos octane booster. 89 would be the lowest i would try
Old Apr 11, 2004 | 07:22 PM
BigTex's Avatar
With the stock timing table, you could run 87 without issues. I've used it and had no problems. I do run 93 most of the time, but thats because I have my timing pumped up and have nitrous installed. I don't see detonation being an issue unless you are running it hard or doing heavy towing. If thats the case, bump it up to 89 octane.
Also, I can fill up with almost any grade gasoline from a rural station that carries unoxygenated fuel, and my truck runs better then 93 big city gas.
Old Apr 11, 2004 | 07:23 PM
BigTex's Avatar
Oh yeah, there isn't any sticker or warning saying that premium fuel is required or needed.
Old Apr 11, 2004 | 07:33 PM
one03sierra's Avatar
Formerly one92rs
Talking
i was fixin to say i see the guys here in houston run 87 in them stock.
Old Apr 11, 2004 | 08:18 PM
67SS509's Avatar
10 Second Truck Club
On my 2003SS there is a sticker on the fuel door that says "USE Premium Fuel Only"
Old Apr 11, 2004 | 11:42 PM
Nine Ball's Avatar
LS1Tech Co-Founder
with the price of gas lately, and it getting higher, I don't want to get stuck in a truck that requires premium fuel. Just another reason to get a diesel I suppose. Maybe I'll get an HD and just make it look like an SS
