Rebuild a used 6.0L?
Old Dec 10, 2002 | 10:19 AM
Scream's Avatar
MOOBIES Moderator
Default Rebuild a used 6.0L?
I'm trying to get my hands on a 6.0L as we speak. The motor is a "slapper" and is being replaced by GM for a new motor. My plans are:
Comp Cams 212/218 cam w/ 918 springs
Converter
Gears/posi
Would it be wise to go ahead and replace the pistons w/ Escalade units and clean up the cylinder walls while the motor is out of the truck? Any other thoughts?
Thanks!
Old Dec 10, 2002 | 10:41 AM
RED2K's Avatar
Default Re: Rebuild a used 6.0L?
I would go and freshen it anyway. Put some better pistons in it and a set of arp bolts throgh it. Maybe a bit bigger cam. You can get away with a bigger cam with bigger cubes.
Old Dec 10, 2002 | 10:48 AM
BigTex's Avatar
I like the comp 212/218 for a 6L. I have one waiting for a 6.0 build up.
If you are going to install new pistons, think about getting it overbored and get some forged pistons. Look in the internal engine section. There is a topic on .030 overboring a 6.0.
Old Dec 10, 2002 | 10:53 AM
Scream's Avatar
MOOBIES Moderator
Thanks guys! I hope that this works out. Sounds like there are quite a few people planning this swap! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 10, 2002 | 11:29 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Read thru this thread about this guy (Phone Tech) rebuilding his knocker 6.0 @ 6000 miles.
http://forums.pickuptruck.com/showfl...77786&Search=t rue#Post177786
<small>[ December 10, 2002, 11:31 AM: Message edited by: Neil 6.0 ]</small>
Old Dec 10, 2002 | 02:08 PM
red53gmc's Avatar
I'd go ahead and bore it .060 over and put some forged pistons/rods in it while it's out. You'll wish you had later.
Old Dec 10, 2002 | 02:28 PM
RED2K's Avatar
it is will clean up at .030 there is no real since in going .060. that is not enough cubes to make a difference.
Old Dec 10, 2002 | 02:54 PM
Scream's Avatar
MOOBIES Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by red53gmc:
<strong>I'd go ahead and bore it .060 over and put some forged pistons/rods in it while it's out. You'll wish you had later.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Will all of the "LS1" stuff work? I priced out a list at thunderracing.com with Lunati conn rods, Diamond pistons and Comp Cams cam and valvesprings...I actually thought that it would be more expensive than it was:
Cam and springs: $560
Gaskets/ARP fasteners: $960
Lunati Conn Rods: $700
Diamond forged slugs: $570
TOTAL: $2800
That way, I could spray it and not blow anything but the tranny! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 11, 2002 | 12:08 AM
Scream's Avatar
MOOBIES Moderator
Has anyone ever seen inside a knocking/slapping motor? What I'd like to do is just swap the cam/valvesprings and throw the 6.0L in the truck. Would that be a bad move?
calsdad
Jun 14, 2023 11:07 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
gmcyukon
Oct 5, 2015 06:20 AM
old motorhead
Sep 29, 2015 08:22 PM
sTNT971
Sep 26, 2015 06:27 AM
