which rearend gears?
Old Apr 21, 2008 | 03:54 PM
BLUES MAN's Avatar
The House is Rockin'
Default which rearend gears?
i need some help i want to swap the gears in my rearend. right now i have 342s, whats gonna be the difference between 373s or 410s?
Old Apr 21, 2008 | 04:20 PM
99LoweredSierra's Avatar
What kind of set-up are you going with?
Old Apr 21, 2008 | 04:27 PM
sickREDsierra's Avatar
just more rpm and less mileage.
need to know what type trans, and what size tires to really use a formula.
Old Apr 21, 2008 | 05:55 PM
BLUES MAN's Avatar
stock trans, tires are 305-45-r22
Old Apr 21, 2008 | 06:34 PM
lady3bglover's Avatar
sounds like the 4.10 is going to be the best ....
I'm in the same situation.. I have 20's and a new cam ready to install. I would like to sit the 4.10 in myself.
Lisa
Old Apr 21, 2008 | 07:27 PM
InchUp's Avatar
The 4.10's will counteract a good deal of that weight difference too that the 22's added. The 305/45R22's are a tad taller than the stock 265/75R16's most trucks have from the factory so the 4.10's will return your final drive ratio on the pavement (after tires factored in) to about stock. At 70mph you're looking to be around 2000-2100rpms depending on transmission slippage/torque converter lockup assuming a 4L60E.
Old Apr 22, 2008 | 10:40 AM
BLUES MAN's Avatar
Smile
thanks every 1 for your help
Old May 7, 2008 | 11:49 PM
AgsWin's Avatar
Registered User
I have a NNBS 08 5.3 Sierra with 3.42 gears, I am getting a level kit, 20's and 33's. I am thinking I need to step up to 4.10's and a TruTrac.
Are there different brands of gears and which brands should I go with? Also, if anybody knwos the Trutrac part number, that would help.
Old May 8, 2008 | 12:57 AM
mds2004's Avatar
Most brands are pretty much the same, but I have read that Precision Gear, Yukon, and GM gears are the best. Ive used Precision gear and GM with no complaints.
Old May 8, 2008 | 01:34 PM
InchUp's Avatar
Check out Ringpinion.com and call to place your order. They'll set you up with the ring and pinion set along with all the necessary installation parts to do a proper hypoid gear swap.
