Rearend fluid change?
Old Jul 15, 2003 | 10:10 AM
Silvette_02's Avatar
Default Rearend fluid change?
Where should I get the rearend fluid from when I change it out? Should I use GM stuff or something like Lucas? How much should I need?
Thanks,
Josh Hucks
NXS Customs
Old Jul 15, 2003 | 11:22 AM
ryan99chev's Avatar
Default Re: Rearend fluid change?
I put amsoil in mine when i changed mine. Gm wanted like 21 a qt and it wasn't anything special except grape scent. It takes almost 3 qt and i used the series 2000 stuff. I am an amsoil dealer and i have never had any probems.
Old Jul 15, 2003 | 11:25 AM
How much do you charg for 3 quarts. I have the G80 rearend, do I need any additives or anything?
Thanks,
Josh Hucks
NXS Customs
Old Jul 15, 2003 | 04:14 PM
Hit Man X's Avatar
Use some syn 75/90 + 4oz of the LSD additive. The drain and fill plugs accept a 3/8" ratchet.
There is a drain plug on the on the underside of the 10bolt and just make sure to PULL THE FILL PLUG FIRST. It would be bad if you could not fill it back up right?
It takes ~2.8 qts from what I remember.
Old Jul 16, 2003 | 09:53 AM
Thanks a bunch!
Turk55
Sep 11, 2015 11:52 AM
Lostinmiself
Aug 28, 2015 06:30 PM
vmaxpro
Aug 8, 2015 10:49 PM
walledition
Jul 29, 2015 08:54 PM
Suburban2500
Jul 19, 2015 04:50 PM
