Rear End Help ASAP
The rear end is gone and I need a new one because the truck will not move. The driveshaft just keeps spinning. I found this Eaton Posi and I wanted to purchase it, but make sure that it is the right one. Here is the link, can you guys tell me if this is the right one because it doesn't say that it will work for a newer chevy 1500. I think it is a 10 bolt 8.5 30 spline unit. Is this correct? I just dont want to but the rear end. Could the actual gears be messed up as well, or it usually the posi? It had a g80 and prior to going out, when making turns, it would hop and skip which leads me to believe that it is the posi unit and not the actual gears. I must admit, I don't know jack about rearends, so all help and feedback will be greatly appreciated.
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
You need to figure out what failed first as it is most likely a spider gear or a axle. It would have made some horrible noises if the ring gear failed or pinion snapped. Check this first then decide on a plan of action. Since you drag I would suggest you swap in a GM 9.5 inch 14 bolt semi floater with 6 lug pattern as it would "bilt in" and be a lot stronger than current axle assembly.
that looks to be the correct one. i forgot who's name most recomend. someone will post up. that seems to be a good price. yourt ten bolt with the eaton and gears set up properly will work fine.
yes it made a loud noise, like a pop. I hope it is not the axles, that would be horrible. When I put it in gear it makes a grinding noise, but it is not real loud. The truck does not move at all. Should I tow it from the rear to prevent further damage and is there anything else I should replace while the rear end is apart? Thanks again.
Snoman, that is probably a good idea, but don't know how practical it is for me since I run about once a month and of course, on a limited budget. What do you think it would cost to do something like that? I plan on spending about 7 or 8 hundred on the rear end now. Don't want it to get too more expensive.
Thanks again, I really appreciate your guys is help.
Originally Posted by Silvette_02
8.6 & 8.5 same thing.
TimDave217
Aug 24, 2015 04:38 PM
shupe
Aug 5, 2015 06:45 PM
