Rear End Cover Torque Specs??
Old Oct 6, 2003 | 01:17 PM
IslandTahoe's Avatar
Default Rear End Cover Torque Specs??
My rear-end cover has sprung a leak. Is there a torque requirement for the rear-end cover bolts?
Would also love to hear everyone's "tricks" to seal this problem area. I have heard people who simple replace the gasket and people who use RTV red gasket maker. Any thoughts?
Thanks.
Old Oct 6, 2003 | 01:42 PM
LS1TECH Sponsor
Default Re: Rear End Cover Torque Specs??
I remeber the cover bolts are like 17ft/lbs or so but really with a 10 bolt cover having the same torque on all bolts is very important and tightend in a stagerd pattern. But paper gasket they use is crap and yeah RTV will probley work well, I use Toyota FIPG (formed in place gasket) and in my opinion is the best RTV and I have never had a problem. You can ask for it by name at a toyota parts store pronounced "FI-PIG." Also I like to put some RTV around each bolt hole and a dab on the bolts. And don't put on too much RTV just a nice .060" bead is adequate.
Old Oct 6, 2003 | 03:52 PM
silent1's Avatar
Here's all the torque info you should need:
http://www.ls1howto.com/
Old Oct 6, 2003 | 04:14 PM
GREGGO's Avatar
30ftlbs for the cover
45ftlbs for the plug
Old Oct 6, 2003 | 04:25 PM
Thanks for the help guys.
As for the LS1howto site, I tried looking there earlier but I couldn't find anything for the rear-end cover. What name is it under?
Old Oct 6, 2003 | 05:33 PM
yellowls1truck's Avatar
that f.i.p.g. stuff really works. i work at a toyota dealership, and i have seen it first hand. it is the best.
Old Oct 6, 2003 | 05:49 PM
Well I guess I'm stopping at the Toyota Dealership on the way home...F.I.P.G. it is!!!
Old Oct 7, 2003 | 12:16 AM
Ok Guys -
Toyota has two versions of their FIPG, a BLACK one for oil pans and cam covers & a RED one for transmission pans. Which one are you guys most familiar with? Is red for hotter temps and black for lower temps? I would think for a rear end cover, the hotter the better.
Thanks
Old Oct 7, 2003 | 01:51 AM
LS1TECH Sponsor
I've always used black FIPG on GM diff covers and 90% of other oil sealing (timing covers, valve covers, oil pans etc). Only for 4runner/tacoma trans pans have I used red.
Old Oct 7, 2003 | 03:17 AM
fullfloatinghd is right, the red f.i.p.g. is for transmissions only. use the black stuff and you should be fine.
TAPyvehc93
Jul 23, 2017 10:54 PM
pjb1972
Sep 17, 2015 02:06 PM
Oobray
Aug 12, 2015 10:56 AM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ketis
Jul 23, 2015 12:37 PM
