rear end broke
Old Jan 2, 2005 | 09:48 PM
11 Second Club
Default rear end broke
When you break the g80, will it lock at all? Or, do you just have a peg leg? Mine is screwed, and I am just guessing what is wrong with it before I open it up. I can still spin both tires, but it is making a bad clunking noise. Also, when I turn to the right it makes the noise over and over until I am going straight.
Old Jan 2, 2005 | 10:07 PM
Mine make a loud clunking noise.Sounds like it's time for a Auburn Pro or an Eaton posi.
Old Jan 2, 2005 | 10:45 PM
GREGGO's Avatar
Sounds like some teeth missing.
Old Jan 2, 2005 | 10:47 PM
hellbents10's Avatar
LS1Tech Sponsor
I have a couple go and they sort of clunk. One of mine split in half, whole carrier f'ed. Funny thing is I have 1.51 60ft'ed the one in the 96' and have still yet to have a problem one.
Old Jan 3, 2005 | 09:08 AM
11 Second Club
Thats what I was thinking, we will see tomorrow.
Old Jan 3, 2005 | 09:21 AM
sfj
auburn seems to hold up pretty well stupidfast has had his since his first motor and hes been through four and it just now broke so i give it my seal of approval
Old Jan 3, 2005 | 11:43 AM
Last Call's Avatar
TOTM: January 2007
If I heard those noises, I would stop driving the truck and change the unit ASAP. I heard these same noises, exept when mine broke under normal driving conditions, it took out the rear end gears abd bearing. A $500 job turned into a $1200 job. Do it before its too late, trust me.
Old Jan 3, 2005 | 01:19 PM
11 Second Club
I drove it home and parked it last Wed. Why would it cost 1200? I can get an Eaton, gears and Master rebuild kit for 540.00.
Old Jan 3, 2005 | 03:16 PM
KeukaZ71's Avatar
ya, might have to open her up and see what is floating around in there
Old Jan 3, 2005 | 05:24 PM
Last Call's Avatar
TOTM: January 2007
Eaton, Master Rebiuld Kit, Axle Bearings, and OEM Gears were 725 plus the labor. If you do it yourself, I guess you would be able to do it for the cost of the parts. I don't feel comfortable adjusting the mesh between the gears.
I could have spent $540 as well. I bought OEM gears which were like 125 more I believe and another $75-100 for axle bearings. My rear end had a lot of metal in it and was afraid the metal went into the bearings. OEM geras are less prone to whining and making noise.
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
