Really need some advice, if in screwing up or not.
Old Nov 2, 2011 | 08:30 AM
youngbuck's Avatar
Default Really need some advice, if in screwing up or not.
Ok guys here it goes, I have a stock lq9 with 317s I recently got some ported 862 heads with PRC 660lift springs, ferrea 2.02 intake and 1.57 exh valves, titanium retainers, multi angle valve job.. milled .030 now have a 58cc combustion chamber. I've been talking to alot of ppl and havnt gotten a consistint answer, so my question is are these heads even worth having on? Should I put my stock 317s back on or are the 862s an upgrade? What is my compression going to be with stock head gaskets on the 862s ? I've heard it will be over 12:1 an thats not safe on a dd. So I've looked into some .065 gaskets to bring the compression to 11.5 :1, does this sound right? I'm really needing done help as this is my dd and need to get this sorted out. Thanks.
Old Nov 2, 2011 | 08:41 AM
youngbuck's Avatar
Dont have pics of the intake port but the size difference is about the same as the exhaust side.
PerformanceTrucks.net Forums - youngbuck's Album: Go fast parts.
Old Nov 2, 2011 | 11:09 AM
mhotrodscooter's Avatar
The better flowing heads or going to help Alot.. It's just your CR is too high. I'm thinking e85 or 110 octane & it would be safe.
Compression Ratio Calculator - Wallace Racing
Old Nov 2, 2011 | 11:43 AM
BlackGMC's Avatar
Resident Retard
I think your quench is going to be screwed up and wont run like it should. I went with 243s with stock head gaskets on my lq9
Old Nov 2, 2011 | 12:20 PM
youngbuck's Avatar
Idk how to use the compression caculater. What is quench?
Old Nov 2, 2011 | 04:44 PM
youngbuck's Avatar
Would I be better off putting my 317s back on? Or can I run this compression with a good tune?
Old Nov 2, 2011 | 06:17 PM
dmelvin's Avatar
Re: What is "quench"? What is a "quench area" Why is it good? n/m
This does a good job of explaining quench. You don't want too much room between your heads and pistons because it won't do a good job of mixing the fuel and air.
bearden86
26
Nov 15, 2015 03:58 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Chevy305
Sep 28, 2015 09:21 PM
Cha_Feel_
Sep 23, 2015 09:06 PM
