Really Confused About Cams
Old Apr 8, 2012 | 11:53 PM
  #21
dmelvin's Avatar
Originally Posted by 01SlowHoe
Hows ur idle with the comp cam? And if I ran that cam and ls6 springs, stock head gasket thickness and recommendations on pushrod length? I'm not trying to half *** this but with it being my DD i dont really have time to pull it all apart and check the pushrod length then wait a week for the right ones to arrive ya know?
Originally Posted by AndysC3
99% of the time the 7.4 pushrods will work. If you plan on racing and spending alot of time in the upper RPMs is when you really need to check lifter preload.I had my heads milled .025 and used a 7.375 pushrod.
Andy is right. 7.4's will more than likely work fine, unless you're planning on changing the lifters to the LS7's, or if you get a cam with a different base circle than the stock cam.
My idle has a mild chop to it. The cam is cut on a 114LSA
This is a video that I made for my brother after I got everything done to it, so ignore my commentary.
Old Apr 9, 2012 | 12:00 AM
  #22
01SlowHoe's Avatar
Registered User
Sounds great! I still wish i could get by with a slightly bigger cam, but y'all know more about this than me lol so i'm listening and taking all advice given which i greatly appreciate.
Old Apr 9, 2012 | 12:06 AM
  #23
dmelvin's Avatar
A cam on a lower LSA tends to have more chop to it. It also moves the powerband to the left, which means more low end. Honestly, I'd get one spec'd for you by PatG. I think if you buy the cam from him, he gives you that $25 back in the price of the cam.
Old Apr 9, 2012 | 12:10 AM
  #24
01SlowHoe's Avatar
Registered User
Okay and PatG is a member on here? or what? I listened to your truck and a few more on youtube and from what i can tell the 212/218 comp cam has an idle i could deal with atleast until I get the money to do alot more to my tahoe to be able to run a bigger cam.
Old Apr 9, 2012 | 12:47 AM
  #25
01SlowHoe's Avatar
Registered User
One last question, would it be okay to drive it un-tuned? Just for a little while maybe a week or so because my tuner stays booked and his shop is 30 mins away.
Old Apr 9, 2012 | 01:34 AM
  #26
AndysC3's Avatar
The 212/218 should be ok to drive around for alittle while untuned. Just take it easy.
Old Apr 9, 2012 | 01:38 AM
  #27
K_ddsl's Avatar
Registered User
Only if you can live with it dying on you in stop and go traffic and almost very time you engage the gear, ect... As it probably will.
Just don't hammer it too hard as you AFR will be totally out of whack until you tune it.
Old Apr 9, 2012 | 07:27 AM
  #28
BigDaddy0381's Avatar
This is my truck with the SDPC HT 1 cam. it is right on the verge of needing a stall i'm adding a fesh tans and a 2500 or so stall. You will need a tune or be really good and two footing.
VIDEO0031.3gp - YouTube
Old Apr 9, 2012 | 08:29 AM
  #29
batboy's Avatar
11 Second Club
The SDPC HT1 cam is what I recommended way back on page 1 of this thread. If he wants a lopey idle, that one will deliver.
Scoggin Dickey Parts Center CC54-ST1-11 - HT1 SDPC LSX Truck Cam 214/218 .559/.562 111 | SDParts - 1-800-456-0211
Old Apr 9, 2012 | 10:02 AM
  #30
SloStepSide's Avatar
