Re-using my 4.8 heads on my 6.0 ??
#22
what would need to be done to the 317s to raise the CR just a simple mill?
What would it take for the 4.8 heads to work? and why would you choose these over the 317s?
What do you think a safe CR would be if i plan on spraying at least 150?
And no meth or race gas.
#25
well I think i came to a decision.
Im going to just use the 317s as is. My reason being is becuase i am on a budget to use the 862s would bump my CR to a point where i wouldnt feel comfortable using spray and the cost of porting them is just that another cost. if i milled dwne the 317s sure i could raise the CR a little and spray it but im not sure how much of the gas i want to use and even though milling would be not much $$ it still would be more.
So with the stock 317s i could spray and still be realativly safe.
Also i figured im going from a cammed 4.8 to a cammed,sprayed,6.0 and my goal of 12s should be attainable and plus with stock 317s i can just spray more if i wanted.
#27
Whats up Goerge,
To be honest i was happy with the 4.8 but the crank bearing decided to start squeeling like a pig. We didnt even get a chance to spray it. (not sure if you seen the N2O setup).
So since the 4.8 doesnt want to play anymore I found me an LQ9 when all is said and done i should have a good moving truck (shooting for 12s) with the 212/218 cam and all the other boltons it should make some nice numbers.
#29
The truck will be finished next week sometime. I will have some graphs to post up most likely next weekend.
Ive heard both sides saying its too small of a cam and others saying its going to make some good #s. I was willing to crak open my wallet for a new cam but i was kinda curious(sp) to see for myself.
