RADIX UPDATE
Old Aug 8, 2003 | 11:58 AM
BlownChevy's Avatar
blownerator
25 Year Member
Default Re: RADIX UPDATE
yeah, I feel the same way......
Old Aug 8, 2003 | 01:38 PM
MarineBlue03GMC's Avatar
Tech Fanatic
thanks for all of your suggestions! Im planning to maybe go to robbins bros. this sunday to maybe pick up the ring. gotta do financing though.
Old Aug 8, 2003 | 02:34 PM
YUKONTURTLE's Avatar
Get a nice setting and mount a cubic zirconia. She won't be able to tell the difference. Then finance the Radix and show her the financing and tell her, "See how much your ring was!"
Old Aug 8, 2003 | 03:50 PM
EXTRAFAST's Avatar
ok guys here is the full 24hour update
stock air box is too small for this hungry beast i have the "when to change air filter gauge" on the stock air box its maxed out indicating i have a dirty filter coool.
ill put my old FIPK kit back on and cut around the shroud to make it fit i think there is more power in there somewhere.
hey thanks for the welcome guys yes its well worth it
hey marineblue i seen some real nice rings for 99 dollars
Old Aug 8, 2003 | 04:57 PM
BlownChevy's Avatar
blownerator
25 Year Member
C'mon man you know we are just bustin your chops!
CZ and the Radix, that sounds nice!
Old Aug 8, 2003 | 04:58 PM
BlownChevy's Avatar
blownerator
25 Year Member
hey extra where are you located?
Old Aug 8, 2003 | 05:46 PM
Tech Fanatic
Yea that CZ idea is brilliant! Gonna do it right now!
Old Aug 8, 2003 | 06:16 PM
Don't use an open element filter,my Radix sucked a K&N cone filter completely flat.I use the K&N replacement panel with a UPD lid and a 4" homemade ramair pipe drawing cold air from below the bumper into the stock air box.You need to shorten the Magnacharger inlet tube to make it work.At the track I remove the filter.
Old Aug 8, 2003 | 06:28 PM
EXTRAFAST's Avatar
Tampa.FL
blownchevy man your truck has the perfect setup how do you like the jet tranny dose it shift like the stock tranny..
Old Aug 8, 2003 | 06:47 PM
EXTRAFAST's Avatar
Whitt1 i have the new K&N filter included with the charger in there i also drilled holes underside of air box might do the ramair pipe next
