Radix and Supporting Mods for 5.3
I want to run mid to high 12's. Currently, I run 13.7's at about 100 mph. Truck has efans, 3.25 pulley, TOG headers with single 3" exhaust, and volant. Here is what I was thinking;
Other things which Im contemplating;
What combination of these mods or others will get me there.
- LPE; gt2-3 cam
- hardened pushords
- Z06 valve springs
- true 3" inch duals
- 6.0 #317 heads
- 3.0 pulley
- meth injection
I've run a best of 13.24 with the 3.25 pulley, stock cam, and drag radials. I'm HOPING with the cooler weather coming up, and race gas, I might be able to hit high 12's. I'd go with the cam, Forget the dual 3" (your present set up looks good), with a little more timing, and meth, you should be there. There's LOTS to be gained in tuning! You're probably going to need some kind or drag radials, too.
I would go with the meth injection, more timing, smaller pulley and some good tires and you should be there. Mjhoward would be the guy to tlak to, shoot him a pm, we put meth/laky injection on his truck, lt headers, cam, and a 3inch pulley and he was putting down like 413hp and 450tq but has since added 5 more degrees of timing and a larger intercooler and he says it runs a hell of alot better he is probably closer to 500hp now. His truck runs damn good.
Originally Posted by BlownChevy
I am against the Meth Injection....not very street friendly IMO......What do you do when you run out?? I think the cam and a good tune will get you where you want to be.
I totally agree with the cam, and tune, but the meth would be a track only system.
Id go with a cam, meth, smaller pulley, and some tuning.
GXPJAY
Feb 13, 2022 08:15 AM
RoidedSS
Aug 11, 2015 11:51 AM
