Radix pulley & Nelson tune install... worried.
Old Aug 20, 2005 | 10:51 PM
CHarris's Avatar
Originally Posted by vortec327
Use a fabric strap wrench or a rubber strap wrench. Also try loosing the nut with the belt still on the pulley first, may not work but its worth a shot.
The new pulley should line up just right.
Mine worked with just leaving the belt on and snug... or if it's slightly slipping use a breaker bar to pull the tensioner slightly tighter and it acts as a strap wrench but without the cost or the trip to the store
I did have to take a few firm taps around the backside of the stock pulley to get it to unseat. I used a rubber mallet- GENTLY.
The nelson pulley is very easy to install with the nut forward. Goes on very easy.
Old Aug 21, 2005 | 09:40 AM
therock's Avatar
Default An Old Belt...
...cut off so a pair of vice grips can clamp it together and simulate a strap wrench.
Old Aug 21, 2005 | 12:45 PM
01Blackerado's Avatar
Originally Posted by JimS
I have some concerns about installing the pulley and tune I received from Nelson.
The instructions for the tune talk about several scenarios that could occur and which would require a relearn or use of a puter scanner. Seems to me I'd better wait to install the tune until I can be at the auto service center that has a computer code reader. Correct? Or is it unusual to get a computer code that requires help.
Help will be appreciated. Thanks, Jim
I've changed out the PCM several times and have only had to do the relearn process a couple times, No big deal, takes about 20 minutes. If anything goes wrong you can always put the stock one back in. Just my 2 cents
Old Aug 21, 2005 | 05:43 PM
JimS's Avatar
You guys gave the information and confidence to get the job done!
I did the pulley and pcm today and what a difference.
The Radix was a huge improvement and this Nelso tune really woke it up! I'm a happy camper.
Thanks for your help. Had you not been here to encourage and support I'd have waited until I could get to the shop and have a mechanic with the puter ready to bail me out. It feels good to have been capable of doing the work myself.
Later Jim
Old Aug 21, 2005 | 06:29 PM
O3GMC's Avatar
12 Second Club
Good to hear you got it going. You already got the pulley on but I was going to add to the comments above that if you use a strip of old belt or something to wrap around the pulley & get in the ribs, THEN put a big rubber strap wrench around that, it works well for holding the pulley in place - just FYI to any one else who hasn't taken the stock pulley off.
Go5.3tt06
Sep 12, 2015 09:29 AM
Ls3silverado
Jul 31, 2015 04:22 PM
01sierraon22s
Jul 8, 2015 11:26 AM
GreyChevy
Jul 7, 2015 08:57 PM
