Radix pulley, how much boost is safe?
Old May 23, 2005 | 08:09 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by 1Blown04
Yes it would be safe. I am running a 3.2 with no knock. I see 9 psi at WOT and 10psi for the last 500rpm's. Adding methynol injection would also help as a safety item and add a little more power in the process.
Did you get a mail order tune or in person when you went to the 3.2? So would I be completly insane to add a NO2 setup or is that even possible with a Radix? Say a......75 shot?
I ran a 3.0" pulley on a 5.3 with no problems.I was seeing about 9lbs of boost.I was also running long tube headers which will lose about 1/2lb of boost.I doubt you'll see much KR unless you run at full throttle long enough to elavate your IAT,even so I would recomend you running an upgraded heat exchanger if your kit didn't come with it.
Mr. Sandog's Avatar
Ideally I would just go in for a tune, have them install the 3.25" pulley, and tune the vehicle after the pulley install. This is the ideal scenario and what I would recommend to a friend, as well as what I would do myself.
Since you seem to not have that as an option, the next best thing is to put the pulley on yourself, and drive around while logging PCM data. First drive around normally and ensure there is no KR. Then increase your throttle while still monitoring for KR, building up throttle.
Since you don't have logging software, you are taking a risk by slapping on the pulley and expecting everything to be okay - especially since you don't know how aggressive your tune is now. Detonation is bad, and can kill a motor. I've seen what it can do to pistons, etc, and it ain't pretty.
Disclaimer: This is all just my opinion.
Old May 23, 2005 | 08:21 PM
1SlowHoe's Avatar
I've heard that Westers tunes are pretty conservative but I don't know. I won't be swapping pulleys until I find a tuner I think knows what they are doing. I may have to take road trip. Know of anybody closer than TX to me (FL)?
Old May 23, 2005 | 08:24 PM
Mr. Sandog's Avatar
Where in FLA are you? We have a few guys here from the Sunshine State,TurboBerserker and BenKey are just two that I know of.
Old May 23, 2005 | 08:30 PM
1SlowHoe's Avatar
I live in Navarre/ Fort Walton Beach. About 40 miles east of Pensacola. About a mile from the beach, this time of year is nice the scenery gets really good.
Old May 23, 2005 | 08:33 PM
Try Futral or Thunderracing both are in the Baton Rouge LA area.
Old May 23, 2005 | 08:42 PM
BlownChevy's Avatar
blownerator
25 Year Member
Boost is only as safe as the Tune, Fuel, and driver.
Old May 23, 2005 | 08:51 PM
1SlowHoe's Avatar
Hmmmmm, the driver......
Old May 23, 2005 | 08:55 PM
Mr. Sandog's Avatar
Point being, if you contact a few of our Florida members, they might be able to put you in contact with a good tuner in you area.
