Radix people.... help please only 2 PSI
#51
Originally Posted by dewmanshu
The boost....ask blownchevy if there is a way to actually test that bypass valve. Make sure it works under vacuum like it supposed to, not just mechanically pushing it in and out.
I will think up some instructions and post them tomorrow. Unless it is messed with, the bypass does not usually fail. I know some people think if you adjust it, it will make more boost. This is the WORST thing you can do, this is not a "blow-off valve"!
