Radix Install ticker
Old Dec 24, 2004 | 10:53 PM
  #51
moregrip's Avatar
what a rush!
Originally Posted by BlownChevy
Geeez man....get er done.
Brother, I'm on watch until Midnight, remember?, tomorrow is a family day after all, I have been a good boy this year
Old Dec 24, 2004 | 10:55 PM
  #52
BlownChevy's Avatar
blownerator
25 Year Member
I understand......butwithout pics of the progress.
Old Dec 24, 2004 | 10:58 PM
  #53
moregrip's Avatar
what a rush!
Even though she will be road worthy on Sunday, I have a feeling I'll be tweaking the kit for a while. I think I'm going to bend up some copper tubing to replace that hard plastic EVAP tubing that's rubbing me the wrong way, can't stop thinking about it. Also, and I know you'll appreciate this, I'd like to redo some of the wiring paths
BTW B, you created the beast, beatch!
Old Dec 24, 2004 | 10:59 PM
  #54
moregrip's Avatar
what a rush!
My freaking picture hosting went over my monthly limit when I posted my wheel/tire pics and magnaflow pics, now they want 3.95 a month for unlimited access, sheesh, freaking $$$.
Old Dec 24, 2004 | 11:01 PM
  #55
BlownChevy's Avatar
blownerator
25 Year Member
If you take any advice from me, it is this: Do not mess with the EVAP. It is very sensetive, once you mess with it it will never be the same.....and you will be setting the SES light about ever 5 drive cycles. If it bothers you that bad (you **** som biatch) take it off and drop it in some HOT water....it will be soft, then put it on and let it harden. Be careful not to kink it or break it.
  #56
BlownChevy's Avatar
blownerator
25 Year Member
I am out for a bit...time to open some Gifts.
Old Dec 24, 2004 | 11:03 PM
  #57
moregrip's Avatar
what a rush!
damn that thing is funky, you need to look at it, it actually lifts the sensor up slightly, kinda crooked..............I'll buy a new one and boil that bitch
Old Dec 24, 2004 | 11:04 PM
  #58
I already did that-im happy got some cool stuff!!!!!!!!!
Old Dec 24, 2004 | 11:05 PM
  #59
Haha i know what you mean.
Old Dec 24, 2004 | 11:17 PM
  #60
moregrip's Avatar
what a rush!
Oh ****, forgot to mention some things and had a couple more questions.
1st, when I hooked up the Neg cable to test for the gray fuel pump wire there were no leaks at the manifold connection as the fuel pump built line pressure so the inner seal must be good to go no damage.
2 questions, did you use that foam tape that comes in the K&N filter box? I didn't see one stock so I left that out as the outer edge of the K&N filter seemed larger than the stock and would already seal better. Am I wrong? does the foam strip need to be installed?
LastQ, ran my fuel line under the rear fuel crossover tube, is this a problem? Seemed to fit better this way, actually, it does, any problem with this?
