Radix IAT sensor
Old Feb 27, 2005 | 11:18 AM
moregrip's Avatar
what a rush!
Default Radix IAT sensor
Who has hooked up a real time air temp gauge to this and how?
if you haven't, what would be the proper procedure for figuring this out? would I have to find out what kind of voltage signal the sensor makes and find the appropriate gauge? or is it harder than that?
Old Feb 27, 2005 | 12:13 PM
Flyer's Avatar
The PCM uses this ... if you hook up another gauge to it, the PCM will get an invalid reading.
Old Feb 27, 2005 | 12:57 PM
CHarris's Avatar
So the only way to monitor is via HP Tuner or some other monitoring software?
Old Feb 27, 2005 | 01:24 PM
Flyer's Avatar
Pretty much .. unless you put in another one.
Old Feb 27, 2005 | 08:07 PM
GMC_DUDE's Avatar
Actually you could connect another gauge, but you would have to be careful not to load the sensor or introduce any extraneous noise. If you're good at designing electronics it can be fairly easy. If not, well... I'd take Flyer's advice and add another sensor.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
