Radix Cam Experts...Need Recommendations/Advice. Tax Time is just around the corner!
#92
Originally Posted by SportSide 5.3
How about this moregrip.
Comp 3711 intake
Comp 3752 exhaust
216/218 .561/.527 113lsa +0
with
6.0L
Mid length, 1 3/4ths
off-road 3 inch y pipe, free flowing muffler
Comp 3711 intake
Comp 3752 exhaust
with
6.0L
Got the free flowing muffler on there, a Magnaflow 22" Case
1 3/4 Mid Lengths sounds good!
Question
How much overlap is there on that Cam?
thanks again!
#94
44.5* @ .006
-9* @ .05
-92.5* @ .2 lift
yeah, i had just thought about the exhaust after i typed that. it's cool though, as long as if flows good.
-9* @ .05
-92.5* @ .2 lift
What do you think of Thunder Racings "Old Man Truck Cam"? Looks interesting......
99-214/220-115+2 Thunder Racing Custom "Old Man Truck" Camshaft - 214/220 .600/.525 115+2 LSA This is the perfect cam for someone looking for a stock range power band and stock sounding idle. Significant horsepower gains throughout the RPM range. No computer tuning required.
Hey Brian (BlownChevy), do me a favor? Run my Cam question by Mr. Magnuson, thanks duddets!
#95
#98
FINALLY!!! picked a Cam.
Comp Cams .581/.581 220/224 XER lobes on a 115 LSA, -8* overlap. This cam should provide me with good idle characteristics and a very healthy midrange due to the XER lobe with plenty up top, and still pass smog. I believe this Cam will pull to 6200rpm. It will also be boost friendly due to the -8* overlap
Thanks for all the help and advice folks......cheers!
Thoughts?
Thoughts?
#100
You should definetly do a before and after dyno.
I'd like to see what a cam that sized does to the rpm-range, not just power.
On a n-a application, you'd see a strong 6200-rpm pull.
Later
Later
