radiator and elec fan setup
well i got a 02 gmc sierra, will a 06 truck radiator bolt right in without any modifications? also what are good fans to go with, i know most are running the ls1 fans, i want to out a stock set of 06 truck fans on there but not sure how i would wire it up to work since i know next to nothing about doing any electrical work
+1 on the Nelson harness, I love mine
As for the 34" rad, it will bolt right in, but you have to trim the 2 rubber flaps on both sides of the radiator to clear, and you'll need 2 extra bolts for the efans or rad. The bolt holes are already there in the upper radiator support for the wider rad, and the 05+ efans use the bolt holes that the old 28" rad used to use. If you have a K&N FIPK, you will need to modify it to clear the rad, not sure about all other CAI's though. The stock airbox clears, as does the Volant. I used to have a K&N and had to trim and "adjust" the heat shield to clear the 34" rad, my current Volant clears no problem
murderedSS
27
Oct 12, 2015 11:13 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
