racetronics fuel pump pic's
Old May 26, 2004 | 05:48 PM
  #21
so racetronix if I wanted to do max 550rwhp you recommend Racetronix PnP harness with a pump booster? that would work on either a 5.3L silverado or 5.3L tahoe?
if so where can i get it?
this is being a plug and play situation with no ***** or switches, you install, set and forget type of thing?
thanx
Old May 26, 2004 | 05:58 PM
  #22
and that Racetronix PnP harness with a pump booster is with only a stock pump for 550RWHP.
Old May 26, 2004 | 07:01 PM
  #23
GMC SKI's Avatar
Both Parish and I have the dual intanks which require you send in the pump sending unit to racetronics to have them modify it
Racetronixs doesn't have a drop in pump for the truck intanks
The harness plugs into your factory stuff and powers the 2 intank pumps
the stock pump is outta it's league at 550rwhp
you would need to upgrade to a custom intank walboro
Pm me if you have any question
Old May 26, 2004 | 07:11 PM
  #24
you see, a stock pump can do 550 rwhp with a booster, I have heard people have supported 700rwhp on ls1s with a racetronix HW kit.
i wanted to know that for sure would 550RWHP be supported with a stock fuel pump w/ Racetronix PnP harness with a pump booster plug and play set and forget idea...racetronix are fuel gods when it comes down to it.
dual race pumps are loud very loud. not interested in that.
thanx though.
Old May 26, 2004 | 08:42 PM
  #25
GMC SKI's Avatar
actaully the pumps aren't that loud as one of them is setup on a hobbs presure switch
so one is running the intank walboro 340 is maybe a tad louder than stock and quiter than a stock pump and inline setup
Imho how long is the pump going to live working that much harder
For what it's worth you can't skimp on the fueling pumps injectors
For sure racetronics are Damn Good at what they do
I've been to there shop in person and met the man behind it all
Old May 26, 2004 | 09:03 PM
  #26
that hobbs pressure switch...its a switch that is set so that when a certain boost level is reached the 2nd pump kicks in?
if you upgrade with a booster and new fuel injectors like 43lb's you should be fine i believe at 550rwhp.
Old May 26, 2004 | 11:51 PM
  #27
Racetronix's Avatar
LS1TECH Sponsor
We do not have a single harness for the GM CK applications as an off-the-shelf item yet as we were putting the production off until the entire pump kits became available. We could quite easily make some up in a matter of days. The harnesses could be used in conjunction with a MSD pump booster which would allow the factory pump to support 550RWHP. This would keep everything fully PnP without the need to drop the tank.
Thunder Racing has our F99 harnesses in stock now so perhaps they would be willing to carry the CK versions as well?
PS. the posts with people supporting apx 700RWHP using a RX harness & booster also were using prototype in-tank pump assemblies or F98 versions.
Old May 27, 2004 | 12:17 AM
  #28
so racetronix can you put a few together, cause I want to buy a few. PM me
Old May 27, 2004 | 12:18 AM
  #29
also that msd pump booster, will work for our trucks...i remember something about our trucks are returnless fuel systems?? im not sure.
Old May 27, 2004 | 04:22 AM
  #30
Racetronix's Avatar
LS1TECH Sponsor
We do not use forum mail or messengers.
Please direct all correspondence to sales@racetronix.com
We will contact Thunder Racing to see if they wish to carry them at this time.
5.3Okasai
Mar 9, 2022 01:07 PM
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
