quick pacesetter question
Old Jan 12, 2008 | 09:17 AM
Rjjtchevy's Avatar
Default quick pacesetter question
hey guy's just wondering if the pacesetter lt's and ory come with gaskets and hardware? and if not does anybody have part #'s. thanks for the help.
Old Jan 12, 2008 | 09:36 AM
kw05silverado's Avatar
yes they do.
Old Jan 12, 2008 | 09:40 AM
xlr82sxs's Avatar
i didn't use the gaskets that came with them because they're prone to failure.. some have had great luck with theirs, but i wasn't taking the chance. so i bought new oem gaskets from the dealership.
it's up to you though.
Old Jan 12, 2008 | 10:58 AM
xlcooplx's Avatar
reuse the stock gaskets IMO. They collector to ORY connections suck. They give you ubolts to use. I'd buy some V-band clamps.
Old Jan 12, 2008 | 07:15 PM
Rjjtchevy's Avatar
alright, thanks for the input guy's
Old Jan 13, 2008 | 01:33 PM
sprayed8's Avatar
has anyone tried using those rally thick aluminum gaskets that are supposed to crush and make a good seal. i think they are called "dead soft" aluminum and made by Mr. Gasket. i've tried four different gaskets and my driver side header still leaks, would these be worth a try?
Old Jan 13, 2008 | 01:43 PM
xlcooplx's Avatar
hmm, driver side header leaks at the head? why not use OEM gaskets? they worked perfect for me.
Old Jan 13, 2008 | 09:02 PM
03 BLACKOUTSSS's Avatar
x2
Everytime I've tried an aftermarket gasket, they leak. reuse the stockers, they work, and you don't have to constantly check the headerbolts.
Old Jan 13, 2008 | 09:28 PM
xlcooplx's Avatar
Originally Posted by 03 BLACKOUTSSS
x2
exactly my thought.
Old Jan 13, 2008 | 10:34 PM
Mangled03gmc's Avatar
Baltimore Whore
They do but they aren't worth a ****. Reuse the stock gaskets, manifold bolts.
John
