Questions about my truck and running some dyno pulls.
Old Jul 9, 2003 | 12:03 PM
1BADHD's Avatar
Default Questions about my truck and running some dyno pulls.
My truck is lifted 6" and I have 35" tires. Will I need to get stocker tires for the runs? Can I leave my speedo set to 35's while running the dyno or does the dyno read the speed from the drum itslef? Has anyone with a 4x4 or lifted truck ever ran a dyno run?
Old Jul 10, 2003 | 08:07 AM
1BADHD's Avatar
Default Re: Questions about my truck and running some dyno pulls.
UH....Buller? Bueller? Bueller?
Old Jul 10, 2003 | 08:47 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
You can run 35's on a dyno, seen it done plenty of times. The numbers will be lower though. A heavy, large diameter tire takes more power to turn the drums. It would be cool if you could do a couple of runs with the 35's then make a couple runs on stock size tires to see what the difference would be.
You might call the dyno shop and ask how they feel about running a non-speed rated tire on the dyno. It would suck bad if a tire failed.
ferrellrooster
Mar 6, 2025 03:22 PM
stealthperf
34
Feb 14, 2016 11:35 AM
black6spdz
Jul 16, 2015 01:32 AM
FlowmasterMufflers
Jul 9, 2015 12:23 PM
