Question about the 4.8
Old Jul 3, 2002 | 01:29 PM
Default Question about the 4.8
I am thinking of trading in the SS and getting a truck. I want to get a Reg cab SWB. Right now the only truck I found that I would remotely consider buying is a 4.8. In the future I want to build up the engine. I am unsure whether or not I will be getting a new block. Would it be "economical" to go ahead and get the 4.8 instead of dropping the extra money for the 5.3? How does the 4.8 differ from the 5.3 besides the bore? Is the stroke different? Can I reuse the crank from the 4.8 or 5.3 if I were to go to the 6 liter block? Sorry for all of the questions. Thanks.
Old Jul 3, 2002 | 01:36 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: Question about the 4.8
If you think you might modify the motor in the future I would just get the 4.8L. You can get a complete 6.0L longblock pretty cheap and it should go in with minimal fuss. Then just sell or keep the 4.8L for a backup.
Is the truck your looking at new or used?
I looked at quite a few trucks and finally found a used one that was exactly what I wanted.
www.getauto.com is a very good place to search for a used vehicle.
John
<small>[ July 03, 2002, 01:37 PM: Message edited by: XLR8NSS ]</small>
Old Jul 3, 2002 | 02:30 PM
2001ss get what you want the cranks are interchangeable betwee n the 4.8 and the 5.3. The way to go is drop in an ls1. you can buy the blocks for half of the cast iron you will lose 65lbs off the front. and you can make good hp on motor. Then put a big shot and run low 12's if traction permitting high 11's
________
Wendie 99
Old Jul 3, 2002 | 03:02 PM
Scream's Avatar
MOOBIES Moderator
The stroke is different on the 4.8L. The rest of the GENIII engines share the same stroke, right?
Old Jul 3, 2002 | 03:59 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by XLR8NSS:
<strong>If you think you might modify the motor in the future I would just get the 4.8L. You can get a complete 6.0L longblock pretty cheap and it should go in with minimal fuss. Then just sell or keep the 4.8L for a backup.
John</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I am unsure if I want new or used.
The stroke is the only thing different between the 4.8 and 5.3? I thought the bore was different. Can someone please back up either statement? Thanks.
<small>[ July 03, 2002, 04:05 PM: Message edited by: 2001SS#3013 ]</small>
Old Jul 3, 2002 | 10:41 PM
CashDudeHomie's Avatar
According to my manual here
4.8 bore and stroke 3.779 x 3.268
5.3 bore and stroke 3.779 x 3.622
6.0 bore and stroke 4.001 x 3.622
BTW there is supposed to be an aluminum block 5.3 coming out in the SSR in a couple months or so.
89sierra
Aug 19, 2015 07:13 PM
08lambochevy
Aug 7, 2015 11:42 PM
RS/SS 4.8
Aug 2, 2015 11:03 PM
USMCvet0311
Aug 1, 2015 07:45 AM
bbowerman
Jul 26, 2015 10:57 PM
