Put cam in straight up or +4
Old Dec 17, 2006 | 07:03 PM
Flyer's Avatar
That makes sense because the stock gears and chain are rather loose.
THe double roller I'm using is not. It's very tight infact. There will be no slop in it for some time.
Old Dec 17, 2006 | 07:06 PM
Flyer's Avatar
Originally Posted by TBSS
Did I miss where the specs are posted on the cam?
No.
Flyer's Avatar
248/254 .622/.612 114+4
Old Dec 17, 2006 | 07:22 PM
ThunderZ28's Avatar
12 Second Club
LUCKY!!!!!!!
going to finaly get it back together Nathan????
One of these days I'll get to do it as well..
Old Dec 17, 2006 | 07:27 PM
Flyer's Avatar
Luck has EVERYTHING to do with it homie. I have a little one on the way a motor to get together, no where to drop it in the truck and no where to get the tranny in once it gets back from the only sucker that was willing to weld the bellhousing back up.
I hope its going to be a monster once it is running though. If nothing else, maybe it'll sound that way with the monster cam.
Did I mention I'll be running stock heads for now?
Old Dec 17, 2006 | 08:44 PM
moregrip's Avatar
what a rush!
if it has 4 deg ground in then I wouldn't advance it anymore unless you have a way of determining what that would do to your power-band.
What did the cam degree in at?
Old Dec 17, 2006 | 11:38 PM
Flyer's Avatar
WHen they degreed it, it was setup retarded 4* which would make it 248/254 114 (no +4).
The big question is ... do I leave it like that or advance it 4 degrees? After looking at DynoSim 2k and what it does for the advance of the cam, I think I'm going to leave it like it is. My biggest concern was if it was going to cause any P-V clearance issue.
Bluchevypick
Aug 18, 2015 09:11 AM
elpyro89
Jul 28, 2015 05:51 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
