Put cam in straight up or +4
Old Dec 17, 2006 | 02:57 PM
Flyer's Avatar
Default Put cam in straight up or +4
I'm getting ready to put the front cover on my motor, and I wanted to get some more opinions before it's all sealed up.
Should I put the cam in where it is (degreed in) or stick to the +4 ground into the cam? Will either one give me more valve clearance than the other?
Old Dec 17, 2006 | 03:12 PM
Rhino79's Avatar
9 Second Club
Putting it in "straight up" is what I would do......dunno about which would give you more P to V clearance though. But with 4 degrees ground in most cams, I would go straight up with it.
Old Dec 17, 2006 | 03:27 PM
FarmerBeau's Avatar
Sexy Party Mod
From what i understand, when you install it straight up, the cam is already at +4 if it is built into the cam. If you advance it another 4 degrees you will be at an 8 degree advance.
See this post about the P2V, its a good read and itll give you some idea of where you need to be. https://www.performancetrucks.net/fo...6&page=1&pp=10
Old Dec 17, 2006 | 03:35 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
That is what I understand too.
Old Dec 17, 2006 | 03:42 PM
Flyer's Avatar
By stright up, I meant 0 advance on the cam. I guess technically, it would be retarded 4* right now.
So .... should I leave it there or use the +4 ground into the cam?
Old Dec 17, 2006 | 03:51 PM
Rhino79's Avatar
9 Second Club
With it installed straight up, its advanced 4*.
Old Dec 17, 2006 | 03:58 PM
jakebdb56's Avatar
well in theory it doesn't matter since you can alter the timing however you like with tuning software. right?
Old Dec 17, 2006 | 04:02 PM
Rhino79's Avatar
9 Second Club
That would only change ignition timing advance, and would not alter the advance of the valve events.
Old Dec 17, 2006 | 04:09 PM
Mr. Sandog's Avatar
Did I miss where the specs are posted on the cam?
Old Dec 17, 2006 | 05:56 PM
Tahoe6.0's Avatar
I was told from my cam grinder that GM grinds LS cams @ 0* and if you use OEM gears / line up the dots, the timing is actually 4* retarded for better emissions. So if, you have 4* advance ground in, youll have 0*using stock gears. Hope I was told correct info! Clear it up Please!
