pushrods lenth for ls6 cam
Old Sep 9, 2004 | 07:02 PM
FILE's Avatar
Default pushrods lenth for ls6 cam
What length of pushrods do I need for the 01 ls6 cam? I was under the impression the 01 ls6 cam has a smaller base circle and therefore it requires a different size pushrod. BTW, this is going on my wife's 4.8
Old Sep 10, 2004 | 08:53 AM
FILE's Avatar
No one wants to give it a shot.
Old Sep 10, 2004 | 10:09 AM
BigKID's Avatar
Some 7.40 will be just fine. All aftermarket cams with higher lifts have smaller base circles. If the had the same base circle and put a higher lobe on it, you wouldn't be able to stick it in the block.
Old Sep 10, 2004 | 12:33 PM
derek_silvy's Avatar
I used stock LS6 pushrods in mine... running fine.... the engine that is, the tranny isn't running much @ all.
Old Sep 10, 2004 | 12:51 PM
FILE's Avatar
Thanks Guys.... I was leaning towards the 7.400". I was just was not sure.
5.3Okasai
Mar 9, 2022 01:07 PM
Jake99
Aug 8, 2015 07:56 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
lxcoupe
Jul 30, 2015 02:42 PM
Aboss
Jul 9, 2015 10:28 AM
