pushrod length
Old Jun 14, 2007 | 07:39 PM
regency's Avatar
Default pushrod length
i measured the stock cam and it measured 1.55" on the mic and the 228R measured 1.45" on the mic. TSP told me that to use stock 7.4" pushrods, but once you divide that by 2 its only .050" difference, should i put the 7.45's in it or just run the 7.4's. i dont really like the fact of only having .030" preload on the lifter since its supposed to have .080"
Old Jun 14, 2007 | 10:15 PM
blown3qtr's Avatar
Did you check both intake and exhaust lobes? Mine were a little different. TSP told me to use 7.4's. I ended up W/ 7.35 w/ about .050 preload. Best bet is to get a pushrod length checker and double check, double check. .030 does seem a little loose though.
Old Jun 14, 2007 | 10:35 PM
regency's Avatar
i might end up putting them in, but for now nahhhh its not ticking so let it be....
Old Jun 15, 2007 | 07:22 AM
blown3qtr's Avatar
If it's not ticking you should be good to go. light preload is better than tight preload w/ hydraulic lifters, for top end power. Hydraulic lifters have a tendency to "pump up" at high rpm.
Old Jun 17, 2007 | 12:50 AM
regency's Avatar
yep, this is very true. never thought about that
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
97_ek
Sep 23, 2015 09:16 PM
bisqikss
Sep 8, 2015 03:35 AM
