pushrod help please????
Old Aug 17, 2003 | 10:54 AM
U LUZ's Avatar
Default pushrod help please????
i am putting together a 5.3 with a lunati55003 cam duration@.50 is 218/221 lift is.526/.534 i am using lingenfelter 60.7 cc heads {ls6----cnc} the push rod i am using is a manley7.450 my question is???????is this the right pushrod for this motor ?????when i installed them i rolled the motor over and no compression ????whats the deal ...thanks
Old Aug 17, 2003 | 01:51 PM
RED2K's Avatar
Default Re: pushrod help please????
That cam should be alright on stock pushrods. that cam is very close to mine and my pushrods are stock. As far as no compression { best swing blade voice} PUT DA PLUGS IN IT UMMMMM HMMMMM
Old Aug 17, 2003 | 02:36 PM
U LUZ's Avatar
our forum member scogin dickey sold me this set up i called them three times and they assured me that they were the right ones...i dont think i bent any valves {i rolled the motor over by hand with a ratchet on the crank bolt on an stand}...i thought something was funny because the pushrods were longer but my heads were milled. and i understand the base circle on the cam is smaller but not that much...were talking 3/16 longer i would have been pissed if i would have tryed to start this thing up and it would have blew up....thanks for the help i just wanted to double check to make sure it wasnt me....
SS94S10
Jan 3, 2019 01:57 PM
JordanH
Nov 6, 2015 07:42 PM
jtphelps289
Sep 29, 2015 12:00 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
97_ek
Sep 23, 2015 09:16 PM
