Pulling out the stall
Old Sep 11, 2006 | 11:43 PM
Default Pulling out the stall
Allright guys, this week I will be pulling out my TCI and puttin my stock converter back in. Do you guys think that I will have any problem with the truck not wanting to run with the cam still in it?
Old Sep 11, 2006 | 11:46 PM
your lack of aftermarket stall will make your truck a pig but it will still run. may try to run through your idle if its too high but other than that, no worry
Old Sep 11, 2006 | 11:54 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Engine will run the same...you just wont have much power under 2600 rpms or so is all.
Old Sep 12, 2006 | 03:44 AM
bluecajun5.3's Avatar
11 Second Truck Club
you still running the tr220?
it will be ok without a stall.
i did it on stock tune and no stall for 2 weeks.
Old Sep 12, 2006 | 07:55 PM
XLR8NSS's Avatar
Adkoonerstrator
Yep, if your idle is raised for the cam coming to a stop will be a little tougher with the tighter stock converter.
Old Sep 12, 2006 | 09:20 PM
litreddevil's Avatar
Banned
you'll be ok if you can get it retuned for a little less idle
Old Sep 12, 2006 | 10:21 PM
Sport Side's Avatar
wannabeslow?
Why goin back to stock?
Old Sep 12, 2006 | 11:33 PM
Ok guys, As long as it will be ok... I dont really wanna pull out the cam but if I have to then I will. The reason is 1 because my g/f and I just had a baby and her car doesnt have a/c. She will be driving it for a while. But it really wouldnt matter if I pulled it out but that leads me to reason number 2. I'm not sure what is going on with this converter but If you go out of town on a long trip or something the tranny will get too hot. I dont have a tranny tempguage but it will pop up in my display center. Then go into the stupid mode where it delays shifts. Also when you come to a red light or something it will buck like a horse. I'm thinking it needs to go back to TCI so they can fix the lockup.
Old Sep 13, 2006 | 12:05 AM
It'll be fine, i've got that same cam except on a 114 LSA, and I run my stock converter. I don't know why people say it'll be a pig down low, mine's not.
I had a TCI 3000 in mine, but it wouldn't lock up right, so I pulled the TCI out and put the stock converter in it. I liked it so much I left it in. It hooks much better and still runs good at the track.
Old Sep 13, 2006 | 12:30 AM
the lock-up issue seems to be a problem with the tci verters.
i'm still running one but it's the upgraded one with the billet cover.
it f'd up on me for 2 days then decided to start working again.
we'll see if it is hurt when i get back home
