pulling heads off !!!
Old Dec 19, 2011 | 07:48 PM
La Blue 05's Avatar
Default pulling heads off !!!
Well guys i wanted to see if yall can help me on this cuz it will be my first time pulling sum heads off and i don't wanna mess up the motor ...the motor is a ly6 with a blowing head gasket i know i will need to remove the intake& headers but wat else and how can i put them on without water going inside the motor...pics would help out better but right now i will take anything thanks in advance! !!!!!
Old Dec 19, 2011 | 08:06 PM
Onetogofast's Avatar
Just get as much as you can off the pistons before reinstalling but the biggest concern is completely cleaning out the head bolt holes so you don't crack the block when reinstalled.
Old Dec 19, 2011 | 08:07 PM
And when done, change oil, drive around the block, change again.
Old Dec 19, 2011 | 08:10 PM
La Blue 05's Avatar
Is there any way to clean bolt heads? ??
Old Dec 19, 2011 | 08:15 PM
1dirtybird's Avatar
A tap, some brake clean and a blow gun. It takes time so dont be in a hurry
Dirty
Old Dec 19, 2011 | 09:46 PM
La Blue 05's Avatar
okay, thanks for the advice guys..so water is in the engine..how can we get it back running?
Old Dec 20, 2011 | 07:43 AM
La MaXxImUs PrImE's Avatar
bump!!!! FELLAS ANY HELP IS APPRECIIATED!!!!!
Old Dec 20, 2011 | 08:25 AM
Robert91RS's Avatar
What are you wanting to know??? Have you pulled the heads yet? If so, toss up some pics or a vid.
Old Dec 20, 2011 | 09:09 AM
01silvy's Avatar
If you have coolant in each cylinder then i would use a wet vac to remove all the excess and then use a blow nozzle on a air compressor to blow all the little stuff out..
Old Dec 20, 2011 | 09:52 AM
dmelvin's Avatar
I soaked it up with a clean shop towel. Biggest thing as stated was be sure you get the head bolt holes cleaned out to keep from cracking the block. I did it with compressed air.
