Pulling the heads..
Old Jan 7, 2009 | 12:07 PM
FstFwrd's Avatar
Default Pulling the heads..
Can the heads be pulled on a 2000 silverado 4.8 with the engine in the truck?
Old Jan 7, 2009 | 01:14 PM
BigTex's Avatar
Yes, this can be done pretty easily. Clean up of coolant and bolt holes isnt fun, but its do-able.
Old Jan 7, 2009 | 01:18 PM
KLUG'S SS's Avatar
FormerVendor
Yeah tell me about I usually got coolant everywhere
Old Jan 7, 2009 | 01:20 PM
ChevyTruck's Avatar
something else
Is there a right up on how to pull the heads?
Old Jan 7, 2009 | 01:26 PM
KLUG'S SS's Avatar
FormerVendor
It's kind of funny as often as I work on and rebuild motors I still make a mess
Old Jan 7, 2009 | 02:32 PM
TXsilverado's Avatar
pull valve covers, remove rockers, remove pushrods, remove 15 or 16 bolts and lift head straight off. you may have to unbolt the transmission from the crossmember and lean the motor forward so you can get the drivers side head to clear the firewall.
wetvac the cylinders out and coat the cylinders to prevent rust.
Old Jan 7, 2009 | 02:41 PM
KLUG'S SS's Avatar
FormerVendor
If you have a higher mileage motor and aren't too confident that the cradles will keep the lifters held up with the cam out you might want to buy or make your own little tools to make sure the lifters stay in place so you don't have one fall into the oil pan because this will **** you off indefinately.
Normally the idea is to spin the cam over a few times with the pushrods and rocker arms removed and it pushes the lifters into the cradle that holds them there but with a higher mileage motor their is always the possibility that a couple of them could fall out and then you will be pulling the oil pan.
Old Jan 7, 2009 | 02:44 PM
00Silv4.8's Avatar
why would you worry about a lifter falling if he's only pulling heads?
Old Jan 7, 2009 | 02:48 PM
KLUG'S SS's Avatar
FormerVendor
Disregard that last post. I am retarded I was talking to somebody about a cam swap on another forum a few minutes ago and my dumbass posted to this thread instead.
Been on the computer too much today and I am starting to lose my mind.
Old Jan 7, 2009 | 03:12 PM
00ChevyScott's Avatar
Wearin' da big hat
I was like "what is this moron talking about?" when I read your post
