pulling 5.3
Old Jun 11, 2006 | 02:19 PM
seeyaa's Avatar
Default pulling 5.3
he guys well the 5.3 almost out just need a cherrypicker but were should i hook the chain to pull it out. well the alt bracket hold it for the front and maybe a bellhousing bolt for the rear.
oh yeah the 5.3 is being replaced by a LQ9
Old Jun 11, 2006 | 07:52 PM
gonzo 6.2's Avatar
Take the intake off to pull the engine,drill a big hole in the back removal bracket to wrap a chain and secure it with a bolt/not,make something simuliar for the front.I did mine with the hood still on.
Old Jun 11, 2006 | 08:03 PM
Quik's Avatar
5 year bitches!
i took alt off and put a chain there and then used a bolt to rear head bolt on passenger side. took motor and trans and harness out as oe
Old Jun 11, 2006 | 08:08 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Drill holes?? Whoa. All I needed to drop my 5.3 in was get two bolts that fit the pre-drilled holes on the heads, bolt the chain to the heads and go. All this was done with the intake and trans all-in-one.
Old Jun 11, 2006 | 08:12 PM
gonzo 6.2's Avatar
Drilling a hole in the bracket is only for saftey,the bracket is the OE bracket on the back of the head drivers side it is there from the factory for a reason R&R,they have a special tool that connects to it.I drilled mine ,you dont have to.
Old Jun 11, 2006 | 08:20 PM
Colby 04's Avatar
Choda
Jan 22, 2026 02:03 PM
ferrellrooster
Mar 6, 2025 03:22 PM
superchomper2003
Aug 26, 2015 09:39 AM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
