Pullies Worth it or not
Old Jul 13, 2006 | 07:31 AM
99LoweredSierra's Avatar
Default Pullies Worth it or not
I am considering getting pullies. are they worth the $230 and heard the gains are about 10hp. Also should i do a 180* thermostat change and how much help will it do?
Old Jul 13, 2006 | 07:51 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Concenses is the 180* is useless and the 160* is a good mod for FI only. You might want to consider a cam before these other mods.
Old Jul 13, 2006 | 08:14 AM
yea im thinking bout gettin the 212/218 high lift but got to get HPT b4 anything
Old Jul 13, 2006 | 11:38 AM
I would put in the 160 stat, regardless of what my mod level was. You're in the South and it get's damn hot in the Summer. Your heater will run at a slightly lower temp, but still plenty hot to get/keep you warm in the Winter.
Getting tuning/logging software is a good plan.
Curious, why are you running TR-6 plugs? Do you spray your motor? I know they're the iridium version.
Old Jul 13, 2006 | 01:28 PM
BradS's Avatar
If you are thinking about a T-Stat you should go look in the southern section at the BB-mod how to
Old Jul 13, 2006 | 01:39 PM
99/5.3w/hips's Avatar
I dont get the t-stat mod. Where I live its been 105+ all summer and my truck constantly runs at 185. Which is on the stock tstat...why would you need any lower then that?
Old Jul 13, 2006 | 02:09 PM
LesPaul's Avatar
pull a trailer in that heat and get back to me
Old Jul 13, 2006 | 02:11 PM
LesPaul's Avatar
back to the question... one of my first mods were pulleys... couldnt be happier... you can definitely notice it from a dig and feel it a bit throughout the rpm range i would suggest it
Old Jul 13, 2006 | 02:34 PM
It is a decent performance mod, but it will bring the sound level down from your system, and basically drain a lot of power from your accesories.
Old Jul 13, 2006 | 02:48 PM
LesPaul's Avatar
hmm didn't hurt mine none... did you get the bigger pulley for the alternator??
