PTV Clearance with this Heads/Cam setup
Old Apr 16, 2013 | 09:06 PM
Low97tahoE's Avatar
Default PTV Clearance with this Heads/Cam setup
So, I'm about to do some work to my 4.8. I'll be running a EPS Cam (214/222 .595 .602 on a 113+2) and 243 heads milled .040 with .040 head gaskets. Will PTV clearance be a problem with this setup?
Old Apr 16, 2013 | 09:14 PM
Byrdman11's Avatar
I think you will be good. But Just check it. Pump up the lifters and zero lash and add .100 turn the engine over by hand and threw the 4 stroke of the engine you are good. just make sure the lifter are pump up tight. I use a old lifter that I open it up make a piece to make it soild checking PTV.
Old Apr 17, 2013 | 08:50 AM
Low97tahoE's Avatar
Alright. Sounds good. Thanks
Old Apr 17, 2013 | 09:19 AM
Atomic's Avatar
I have a gauge for that
A better way is to put a checker valve spring on a cylinder and measure the clearance with a dial indicator. Its usually closest 5-15 degrees ATDC.
simman22
Jan 21, 2017 10:27 PM
zblee
Nov 11, 2015 12:41 AM
Justin87gn
Sep 10, 2015 12:06 PM
LSX-81-SIERRA
Sep 5, 2015 02:51 PM
