pro's and cons of a UDP
Old Oct 19, 2011 | 09:09 AM
Area47's Avatar
Default pro's and cons of a UDP
i more or less know the pro's of the udp. more power.
however, from past experiences with smaller motor's, the idea of udp's being used has lead to oil leaks and sometimes engine failure due to them using this as a counter/balance device. however, i don't hear about failure issues on the lsx side of it, or the people do not say anything if something does go wrong.
i know there is a trade off with everything that you do to a motor.
instead of the good side, lets hear the bad side of it.
Old Oct 19, 2011 | 07:30 PM
AudioPh1x's Avatar
from what ive heard the pros outweigh the cons with UD pully
Old Oct 20, 2011 | 01:15 AM
06Sierra2's Avatar
i havent seen any cons with mine. stock alternator, alt. pulley. i installed the udp with a arp bolt and havent had any issues.
Old Oct 20, 2011 | 02:02 AM
caddy03pimpin's Avatar
I had one put like 60k miles without any issues
Old Oct 20, 2011 | 05:43 AM
zero2sixT's Avatar
only real con is installing it while the engine is still in the truck.
Co-ordinate installing one with a cam swap, imo.
Old Oct 20, 2011 | 05:18 PM
LS1TRUCKGUY's Avatar
Had mine on for 60k+ miles... no issues... I did swap to an overdrive alt pulley when I went from ls1 efans to 34" truck efans
Old Oct 22, 2011 | 05:04 PM
ShredSled's Avatar
I've got an SLP UDP on my Sierra and no issues whatsoever, and have lightly contemplated putting one on my Silverado now too, but it has a much rougher idle and a bit of surging in stop and go with the cam that's in it, which even with stock balancer it tends to dim the headlights at night when surging and I'm a bit apprehensive that the UDP on this motor might make the dimming worse...? What do you guys think?
Old Oct 23, 2011 | 03:09 PM
dug's Avatar
dug
Banned
I put one on my 4.8 20k miles ago. So far so good. I mainly did it to slow down the accesories from the gear change. 3.73 to 4.56.
made a noticable difference in performance.
Old Oct 23, 2011 | 03:17 PM
chevyboy.520's Avatar
Should work well with your current mods, I'd go for it if your staying N/A
If you have the proper balancer puller and tools shouldn't be to hard to install
Old Oct 24, 2011 | 12:33 AM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
most people say that it should be a last bolt on & having put one on my 4.8, I agree with that. I didn't notice any improvement after installing mine. Make sure you use the chrysler pulley remover(I think it's a power steering pump pulley remover) that's available for rent from a parts store or use a 3 jaw puller. I had a hell of a time removing the stock one with a 2 jaw puller. I installed an alternator pulley at the same time & didn't experience any drop in voltage.
I say put that $200 toward a circle d converter
