Proper Seafoam usage in crankcase? (with Radix)
Originally Posted by Naked AV
So what should I do? Are there two different systems or not? Should I just dump the whole pint into the oil fill hole?
Originally Posted by moregrip
If it was me, I'd put a 1/2 to 3/4 can in the crankcase i.e. Oil Fill.
Seafoam will break down your oil. Ignore this suggestion.
grippy - "I'd pour 16 ounces of a highly concentrated de-greasing flamable solvent straight into my oil fill"
Adkoonerstrator
I wouldn't do it, just my opinion though.
Maybe I'd try it in a old beat up 400,000 mile 1979 engine that had sat for a while and was dirty but, a brand new engine. I'd just keep the oil and filter changed at regular intervals and leave it at that.
Now the stuff works wonders cleaning out the intake/TB.
I have no experience running it through the fuel system either, not sure how it could hurt that.
Maybe I'd try it in a old beat up 400,000 mile 1979 engine that had sat for a while and was dirty but, a brand new engine. I'd just keep the oil and filter changed at regular intervals and leave it at that. Now the stuff works wonders cleaning out the intake/TB.
When Added to Crankcase (Oil)
Frees sticky lifters and rings
Increases R.P.M.'s vacuum and compression
Cleans dirty parts
Removes moisture
Cleans PCV valve systems
One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart).
Cleans dirty parts
Removes moisture
Adkoonerstrator
Cleans dirty parts
Removes moisture
Cleans dirty parts
Removes moisture
Fresh oil/filter, keep changed regularly.
