Projected Dyno #'s??
Old Dec 29, 2003 | 04:54 PM
GREGGO's Avatar
I say ~420 also...I also think getting over 400 with the stock pistons and rods 4.8 means you may not have 4.8 for long. Good luck. I really need to change my name now.
Old Dec 29, 2003 | 05:17 PM
parish8's Avatar
single digit dreamer
Originally Posted by parish8
now here is the question, can you dyno more than a stock 6.0 with a 150shot
ok, you got me with your old numbers, my best hp was 387, now where are your new numbers?
Old Dec 29, 2003 | 06:24 PM
LOW2000's Avatar
How much compression are you losing with the thicker head gasket?
Old Dec 29, 2003 | 11:33 PM
8ALTNG's Avatar
Low right now we think the engine is at about 10:1. We would like to think it would get down in the 9.5:1 or lower range but we really cant tell yet. What is the most power that anyone has seen out of a LS1 with stock internals???
Old Dec 29, 2003 | 11:57 PM
Ryan23silverado's Avatar
you should be more around 9:1 comp I would imagine being a stock 4.8L and using larger cc chamber LS1 heads
The highest hp stock internals LS1 (5.7L) is somewhere around 600rwhp I don't think things last too long in that range though -even with a dead on tune.
Old Dec 30, 2003 | 12:15 AM
8ALTNG's Avatar
[QUOTE=Ryan23silverado] you should be more around 9:1 comp I would imagine being a stock 4.8L and using larger cc chamber LS1 heads
Ryan i honestly am not sure what the comp ratio is. Agestino Racing did the heads and they said they are 9.5:1 or 9:1. I thought that they said 10:1 but when i went back and looked it was 9 or 9.5. I would like to have it be right at 9: or even lower. as for the stock internals lets just say that once they go something forged will be waiting to replace the whole set up.
Old Dec 30, 2003 | 12:17 AM
BlownChevy's Avatar
blownerator
25 Year Member
[QUOTE=LTNKLR01]
when do you get the dyno results?
Old Dec 30, 2003 | 02:42 AM
454SuperSport's Avatar
you got a stall or still running stock converter? i'd say ~450hp
Old Dec 30, 2003 | 07:11 AM
8ALTNG's Avatar
Blown: it will be about a week to 2 weeks before i get the results. I told my mechanic no rush on the truck seeing as how I live in NEw England and it is winter so that means cold, wet roads. But as soon as i know the results you guys will.
454: I have a yank 3000 stall convertor
Old Dec 30, 2003 | 09:47 AM
BlownChevy's Avatar
blownerator
25 Year Member
Cold, you think its cold!!!!
Its a freezing 62 here!
