programmer?
Old Oct 21, 2004 | 02:31 AM
jeffy-jam's Avatar
Question programmer?
i have a 2000 silverado w/ a 5.3. i have put headers, dual exhaust, k&n filter, and a hypertech programmer into it. i am thinking of changing my cam to gmpp part #12560950 it's specs are duration @ .050" 207/217 lift .525"/.525". hypertech says the programmer will not compensate for the increased lift and duration. what is a better programmer or would it be better to go to a dyno somewhere and if so any idea where one is around pittsburgh? i live about 45 min outside of pittsburgh in wv. any help would be awsome
Old Oct 21, 2004 | 02:33 AM
Nelson.......
Old Oct 21, 2004 | 02:39 AM
yah.... get a Nelson
Old Oct 21, 2004 | 05:39 AM
one03sierra's Avatar
Formerly one92rs
Talking
a custom tune will be needed to make the most out of a cam install. you will also need to do at least some ls6 springs with that cam also.for the most part i believe it will run but i think the only thing you will be able to use is the shift points with the hyper.
Old Oct 21, 2004 | 06:10 PM
superchargedchevy02's Avatar
MTI Tune the only way to go
Old Oct 21, 2004 | 06:30 PM
SallyDaGMC's Avatar
where is this nelson tune?
Old Oct 21, 2004 | 07:01 PM
mrr23's Avatar
10 Second Club
http://www.stealthram.com/vhptuner.htm marc_w is using it. he also did a cam swap. there's another truck guy here using one also.
Old Oct 21, 2004 | 07:39 PM
OUT2WIN's Avatar
nelson tune is the way to go. You can check out his website or give him a call.
Old Oct 21, 2004 | 07:59 PM
budhayes3's Avatar
PT's Slowest Truck
I'm currently using it and it's great. Truck was a dog after the cam swap, now it's actually fun to drive. Bumped my idle up 50 rpm and compensated for the larger 02 6.0 injectors I swapped in (99's have 21 lb injectors, 00 and up are 24.7). I went with one of the pre-set cam profile tunes and played around with timing and fuel a little bit too. Hardened up the shifts and increased shift points.Great customer service too...I give it two thumbs up.
Old Oct 21, 2004 | 09:43 PM
Formerly one92rs
Talking
go nelson. he will net more hp than mti anyday.
