ProCharger questions....
Old Dec 27, 2003 | 06:34 PM
TwoFast's Avatar
Yelo, What types of problems have you had with Vortech and Powerdyne?
Old Dec 27, 2003 | 09:13 PM
gmc5.3,all of the supercharger kits have pros and cons.No one leaves them alone Radix and Whipplecharger with increased boost are extremely hard on transmissions and rearends because of the instant boost at low rpms,Prochargers and Vortecs, because of the high rpm boost they are capable making are tipacally engine breakers.Unless you can afford to replace expensive parts you probably shouldn't mess around with either type.I know the cool factor of having a supercharged truck is strong,but living with a bolt-ons truck is a lot cheaper.
Old Dec 27, 2003 | 09:16 PM
StupidFast's Avatar
I had a problem with surging at idle with 16-18lbs of boost. It would blow the tires off at 80 like nothing. I took it off to go with a juice setup. I had a stock bottom end and it lasted for awhile. I took the blower off, started tuning the juice, and the pistons had a little problem. I believe the motor was already hurt.
I made a good amount of power. If I had to do it again I would leave the 12lb pulley on and put a small amount of squeeze. I would also strongly recommend a D-1SC, you can use a larger pulley and have more belt wrap around the pulley. I would also suggest a Z06 cam, it would cut down the surging problem and it also a very blower freindly (at least for centifugal blowers). Also stay with a small amount of juice. Someone posted a gain of over 90rwhp with a 40shot in the forced induction forum.
Just my opinion.
Old Dec 28, 2003 | 09:08 AM
Black Blown 02's Avatar
Originally Posted by Yelo
I am leaning towards a centrifugal supercharger after I do the heads and cam.....since I already have enough low-end to roast the tires at will and I can get off the line pretty good I think I can get away without the low-end produced by a Roots or Twin-Screw supercharger (Sorry BlownChevy...no RADIX sale here....)
Does anyone have and input positive or negative on the ATI ProCharger....this would be my ONLY choice in a centrifugal charger due to previous bad experiences with Powerdyne and Vortec
also....assuming 7-psi of boost, what kind of N20 shot can I run off the line to help with the 60' time ??.....I was thinking 50-75hp shoud be safe
If you already have plenty of torque off the line, then why are you planning on spraying it out of the hole?
Old Dec 28, 2003 | 11:33 AM
Yelo's Avatar
gmc5.3L....a buddy of mine that owned a Mustand 5.0 went through like 5 Vortec compressors (bearings and case cracks) before he gave up and sold the car, and EVERY Powerdyne supercharger I've seen has bearing problems
Black Blown 02...strickly for the 60' times at the track.....on the street I REALLY don't like to run in 4x4 because of things like corners so the juice would NEVER be used there.....but at the track I can drop it into 4x4 and spray it out of the hole in a straight line
Old Dec 28, 2003 | 11:51 AM
I see.If you plan on only spraying to 4500rpm or so, I think you could easily spray a 100 shot out of the hole if you have a window switch or a 3000+stall.
At 7psi, you'd only be around 2psi at 3000 and 3-4 psi at 4500. So at those rpm's you'd be able to take pretty much what a stock engine would take.
Definately go with the D1SC.
Old Dec 28, 2003 | 12:10 PM
Yelo's Avatar
I'd lke to go with 10-12 psi @ 5500-6000 if it is possible....without doing engine damage
Old Dec 28, 2003 | 12:18 PM
I'm running 11psi at 5900rpm right now on 91 octane 12/1 afr without knock.
I also plan on running a 75-100 shot on race gas next summer.
I think 11-12 will be pretty safe with a good WIDEBAND tune. Do you plan on getting a wideband setup?
Ask around and find out what size pulley you'll need for your setup D1SC 11-12 psi, and buy it from Reichard Racing. Their pulley is sweet, and will lessen the chance of belt slip.
Old Dec 28, 2003 | 12:25 PM
MHLY01's Avatar
I have had an ARE H/C kit on ym truck with a ATI P1SC for about a year now. No problems at all. I have the smaller pulley, Lapole headers, 42lb injectors, and custom LS1 Edit tuning. The truck is fast, plenty of low end torque and it screams on the0 top end when spooled up. It is really pushing the limit of the stock tranny which is going to be gone pretty soon, got to get an upgrade No problems with the P1SC, the D1SC is alot louder. Never measured how much boost, I need to go back up to LG and have them do a checkup and tune up sometime soon so we will see. Can't dyno either because its a AWD C3.
Old Dec 28, 2003 | 12:28 PM
Yelo's Avatar
Yes...a wideband setup is in the future, as well as LS1Edit (cmotorsports is doing my tuning right now)
What kind of power numbers are you putting down??...and when can you feel the boost kick in (rpm) ??
