problems with ASP underdrive pulley
Old Sep 17, 2011 | 02:07 PM
getchusum99's Avatar
Default problems with ASP underdrive pulley
i heard from a few people at work , that underdrive pulleys can harm your timing chain and or valve train overtime ,due to the oil pump turning slower.ive had one on my truck before , for about a year and no problem. but no my engine has 280k on it and just wonderin. thoughts?
Old Sep 17, 2011 | 02:18 PM
neilownz's Avatar
Should be turning the same amount since those aren't ran off the belt.
Old Sep 17, 2011 | 03:44 PM
grey matter 04's Avatar
13 Second Truck Club
oil pump is crank driven so it spins the same no matter what pulley is bolted to it
Hear say will often steer you in the wrong direction
Old Sep 17, 2011 | 03:50 PM
TIM Z's Avatar
11 sec. Truck Mod
x2 !!! Well said.
Seems everyone knows what is best for ''YOU'' haha !!!
Old Sep 18, 2011 | 04:45 PM
LS1TRUCKGUY's Avatar
As said above, only your belt driven accessories are slowed down with a small crank pulley
Old Sep 18, 2011 | 06:29 PM
1989k1500's Avatar
Unless you have a dry sump setup it wont affect your oil pump. lol
Old Sep 19, 2011 | 07:25 PM
i knew the oil pump was gear driven. guess i wasnt thinking, lol., what about the wear and tear from the lack of a dampner?
Old Sep 21, 2011 | 11:24 AM
02'Z71ONDUBZ''s Avatar
have you ever looked at your crank pulley? lol
Old Sep 21, 2011 | 11:43 AM
Alpinestar's Avatar
Z06 MS4 cam balancer incident - YouTube
Don't be like these idiots and not install a new harmonic balancer bolt . Also, if you have upgraded to efans you might think about getting an overdrive pulley for the alternator.
Old Sep 21, 2011 | 09:55 PM
how many ft pounds should the torque of the crank bolt be?
