problem with my '94 Chevy
Old Jan 20, 2008 | 06:12 PM
MaxFubar's Avatar
Originally Posted by YenkoST
How's your compression looking...do a compression test.
Compression checks out. All around 150-ish.
Old Jan 22, 2008 | 08:40 AM
shandy294's Avatar
fuel press chk couldn't hurt...is it still on the original pump?
Old Jan 22, 2008 | 12:07 PM
MaxFubar's Avatar
Delco pump installed 50K miles ago, fuel filter changed every 10K. Pressure checks out. Still looking for ideas
Old Jan 22, 2008 | 12:16 PM
White Lightnin's Avatar
Had a 98 z71 that did the same thing. It turned out to be the fuel pump. It would backfire and act like trans was slipping.
Old Jan 22, 2008 | 01:25 PM
YenkoST's Avatar
Compression is low...should be about 190-205-ish.
Stock tune or modified tune?
Old Jan 22, 2008 | 03:23 PM
MaxFubar's Avatar
it's stock, I though 140 to 160 was ok.
Old Jan 22, 2008 | 03:26 PM
YenkoST's Avatar
Naw...a stock engine on compression psi should be 190-205.
Old Jan 23, 2008 | 02:38 PM
10 Second Club
Yeah maybe but he said it has 300k miles on it and 140-150 isn't bad for that many miles on a 5.7
Old Jan 23, 2008 | 02:43 PM
YenkoST's Avatar
Yea, I understand it has 300k on it but low psi means fuel/air is getting by which could be causing a leaner condition when off the throttle.
Other than that, its timing related. If you have advanced the timing at the distributor, set it back to "0" stock with the EST line disconnected. If you haven't touched it, advance it 4 degrees and see what happens.
Old Jan 23, 2008 | 11:24 PM
Slo-Mo-Shun's Avatar
Originally Posted by oldred95
A handy way to probe your wires without puncturing the insulation is to strip about 3 or 4 inches of a piece of scrap wire and seperate out a couple or strands, twist those and then unplug the throttle position sensor and place them in the terminals and then fold the excess wire back towards the harness and plug the connector back in. Some say this will spread the terminals but if you only use a couple strands it shouldn't and it is a simple way of probing without puncturing the harness.
Another easy way is to slide a straight pin between the weather tight rubber seal and the wire insulation on the backside of the harness connector. The objective is to make contact with the backside of the "pin" inside the connector. This will not spread the terminal. This terminology is called "back probing."
kainzien
Nov 10, 2023 11:37 AM
TN94Z
Mar 2, 2017 05:06 PM
legerwn
56
Nov 15, 2015 10:21 PM
drummer0415
11
Oct 24, 2015 08:16 PM
Glenn98ZM6
Sep 18, 2015 07:31 PM
