Problem with FAST LSX rt intake
yeah they do, mine came with the new bolts. i don't know why that poor guy got his with out the bolts. he should just call and ask for them or just get them at a local parts store
I did change the bolts, I put the ones that came with the manifold . I think they called buttonhead bolts, you have to tighten them with an allen wrench. But the heads were milled .050. They didn't think about people modifying the engine before buying the manifold. They figure it to fit on a stock application. That's what the guy from the tech line said.
You could probably use a set of spacers such as what Moregrip had for sale the other day, which would space the intake up and keep you from having to grind into your brand new expensive intake manifold. I believe he said he picked them up from Magnacharger.
this is JUST a guess! but what about taking the wires and running them towards the intake ports on the heads. like run the wires between the head and the valley cover, there should be enough gap to run that there. like i said im just guessing, ive never milled a head that far.
It's mostly on the bottom that I have fitment problems.
that would really suck..
