Predator fried my computer!
Old Jan 3, 2005 | 01:23 PM
032500hd's Avatar
Default Predator fried my computer!
I have had a Predator in my truck for the past year. Had lots of problems at the beginning (went thru 3 programmers before one finally worked) Diablo did work with me on these problems. I had some tranny issues and took it to Gm and they reflashed the computer and put a factory downshift update in the computer. I left it alone for about a week then went to put the predator program back in and it went about halfway then froze. I had to have gm come get it and they said that the pcu had internal failure. They replaced it under warranty (lucky). I will not be using the predator programer ever again. Also have a buddy that installed the predator into an 03 Tahoe and he lost his computer (don't know if it was because of the predator or not) Maybe it has something to do with the 03's. Or just bad luck on my part.
Old Jan 3, 2005 | 01:35 PM
TG02Z71's Avatar
I've had mine for about a year as well and have had no issues after the intial problem on the first day of using it. It froze up and just said communicating for 2 freaking hours!! I unplugged it and turned the ignotion off then back on and the truck was fine. I have also heard that messing with the door locks and anything else can cause problems but that is all hersay. As of now I do not have a Predator tune in my vehicle, just adjusted all the parameters for shifts, pressure, quickness, fuel at WOT etc. and have no issues. I have heard all this before and I think if I had to do it all again I would have went to Nelson Tune instead, Allen is a good guy and would retune your pcm if you did not like the tune you bought. Many others will tell you the same. The thing that sucks the most is the Predator links itself to your vin# and cannot be used to tune anything else. This is how they control you not using it on multiple vehicles and tuning others for a price I guess. Good luck with your truck man.
Old Jan 4, 2005 | 12:03 PM
leochevy2001's Avatar
For $75, you can send your programmer to diablo and they will unlock it for you.
Old Jan 4, 2005 | 04:25 PM
badpewter-z's Avatar
LS1TECH Sponsor
happened to my old 01 sierra warranty fixed it and then i left it stock
honestly i think ls1edit is the way to go as opposed to these "unirversal" style programmers . or go with some of the sponsors that do mail order tuning .
usally if your battery power gets to low it will freeze the programing and leave you with a fried computer . thats one of the most common reasons ive seen
Old Jan 4, 2005 | 05:34 PM
032500hd's Avatar
I had a good battery. Gm checked it out. Voltage was good battery was good. Because of my problems before I am good at putting the program in and have done it a lot. I ordered a Nelson tune so I will see how it goes. Also according to Allen @ Nelson it's not common but any handheld can fry the pcm and it does happen from time to time.
Old Jan 4, 2005 | 05:35 PM
one03sierra's Avatar
Formerly one92rs
Talking
yep had one of them before and finally got a custom tune. never went back.
RustyD
May 23, 2016 07:04 PM
legerwn
56
Nov 15, 2015 10:21 PM
Cammed4ever
Sep 30, 2015 03:38 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
supershift67
Sep 18, 2015 08:21 PM
