PRC Stage 2.5 LS6 Heads Discontinued
I was looking to order a set for stage 2 of my build and got a call that they no longer make them this way. Anyone think there is a problem with the stage 2.5 317s milled to 65 cc chambers instead?
I appreciate the info but those are the smaller valve stage 1s with single beehive springs (unless i am not seeing what you meant). Anyway, is there any reason to decline the switch to the 317 casting instead? Max boost will be around 10 lb.
I wouldn't even worry about ported heads to run that amount of boost. Run your stock heads. If 10#s doesn't make the power you want... more boost.
Put the head money in the fuel system, or getting the power to the ground properly.
ARC
57
Feb 21, 2022 10:54 AM
CashDudeHomie
Aug 3, 2015 10:58 AM
KyleW707
Jul 29, 2015 08:17 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
