PRC stage 1 ls6 heads on cammed LQ4
Old Mar 6, 2014 | 09:31 AM
Vortec350ss's Avatar
How much did you plan to spend on the cam, heads, and all the supporting mods?
By the sounds of it you would be MUCH happier with a used MP112 from the classifieds. It will give you way more power there you seem to want it.
Old Mar 6, 2014 | 08:07 PM
saltwatercowboy6355's Avatar
Check out the truck in my sig I have stock 317s now you will prob be around the same or just a little under
Old Mar 6, 2014 | 09:23 PM
jdelp's Avatar
Registered User
Thanks SaltwaterCowboy,
You have a little larger cam and a fast 102 making 350/365 so if I can hit 330 with my setup that would be great. I think I will just run the cam and some Boltons and see if I am happy with the results. Might try to pick up a used MP112 in the future. I tow up in the Rockies so I think the boost would be better then hi compression...
Old Mar 7, 2014 | 08:20 AM
Oh god for towing a H/C/I combo will never be as strong where you need it as force feedign the motor.
If it was me I would abort your current plans and start saving for that 112 and headers.
Old Mar 7, 2014 | 05:41 PM
jdelp's Avatar
Registered User
Boost seems to really help at high elevations, that's probably the way I need to go. I might still think about the PRC 243's if I can find a good used set for a nice price.
I know some cams are much better then others for forced induction, how would a 216/220 .560" lift on a 114 work with 7psi of boost?
Old Mar 7, 2014 | 11:10 PM
It'll be ok. There are a lot better.
It's hard to tell you without specifics about advance or retard ground into it. What I can say is that a larger split between intake and exhaust duration would work better. Say 216/224
Old Mar 7, 2014 | 11:13 PM
WICKEDOWESIX's Avatar
I am running the same heads on my set up and put down 485/459.
Old Mar 8, 2014 | 11:14 AM
You also have a shitload more cam and spin your engine up to 6700
Old Mar 9, 2014 | 10:28 PM
jdelp's Avatar
Registered User
Hey,
My cam is a 216/220 .560" lift, 110LCA with 114LSA, so I think that means I have 4-deg advanced ground into it. I think I am going to just run the cam with my stock 317's for now. I do have a Volant CAI and Doug's ceramic headers. I'm sure I will be getting the itch for the PRC stage 1 LS6 heads in about 6 months, so I can give some figures of before / after numbers.
By the way, I have a reputable performance shop doing the install for $550 labor, $350 full street tune. They are going to install the below, does this sound like a good deal for the labor?
Cam, rods & dual PRC springs
New valve seats, seals and retainers
New Ported LS6 oil pump
New LS2 timing chain
New spark plugs 1-deg colder
greedygenius
Sep 3, 2015 06:51 AM
JFortner5
Aug 12, 2015 08:46 PM
KyleW707
Jul 29, 2015 08:17 AM
steves86ta
Jul 28, 2015 10:21 AM
Aboss
Jul 9, 2015 10:28 AM
