is it possible to use 706 heads on a 408stroker?
Old Dec 5, 2007 | 09:22 PM
xdanny510x's Avatar
Default is it possible to use 706 heads on a 408stroker?
im on a budget right now until maybe the summer and im about to order my 408 stroker.. but im not gonnahave enough money for the L76/92 heads manifold package.. so i was wondering if i can use the 706 heads off my 5.3 or if i can use some 243s
Old Dec 5, 2007 | 11:44 PM
BigTex's Avatar
Physically you can use them, but they will limit power. Another thing to consider is the compression ratio you want from this motor. Starting with small heads might mean a larger dished piston, but then buying larger heads in the future would lower your CR. A set of 6L 317 heads might be a little better choice.
Old Dec 5, 2007 | 11:50 PM
xdanny510x's Avatar
which would be better for now until mid summer
the 706s or the 243's?
Old Dec 6, 2007 | 12:45 AM
ap2002's Avatar
243's for sure...
Old Dec 6, 2007 | 09:45 AM
Tootall's Avatar
5.3 heads on a 408 is like trying to stuff a gerbil through a mouse hole.
Old Dec 6, 2007 | 10:23 AM
silver-mod-o's Avatar
Hunt&Fisherator
If you are trying to stay with some inexpensive stockers get some 243's for sure... the 706's could do decent if they are ported all to **** and back but its almost not even worth it since you'll have a bunch of money wrapped up in a head you really cant use on that motor efficiently. The 243's will do you much better until you get what you are looking for.
Old Dec 6, 2007 | 10:57 AM
dkota1968's Avatar
243's, i talked to a builder not too long ago and he said they would be fine for a 402.
lsxmalibu
Sep 9, 2015 11:08 PM
03regcab sierra
Sep 9, 2015 02:02 PM
axekick
Sep 7, 2015 07:01 PM
BigEd_72455
Aug 8, 2015 07:37 PM
sauldgold
Jul 23, 2015 02:15 PM
