Possible to reset pcm on y2k 5.3 ??
Old Aug 19, 2002 | 10:08 PM
SS SLP2's Avatar
11 Second Club
Default Possible to reset pcm on y2k 5.3 ??
useing reset as Y2K LS1 SS ??
(1. Turn the ignition key to the on postion but don't start the car. 2. Remove PCM BAT and PCM ING fuses that are located in the engine compartment. 3. Wait 5-10 minutes then turn the ignition key off. 4. Replace the fuses and start your car.)
also will reset clear misfire code?
thanks for all replys Johnny
<small>[ August 19, 2002, 11:23 PM: Message edited by: SS SLP2 ]</small>
Old Aug 20, 2002 | 07:29 PM
jlwz71's Avatar
Default Re: Possible to reset pcm on y2k 5.3 ??
Yep, that will do it. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 20, 2002 | 09:48 PM
SS SLP2's Avatar
11 Second Club
Thank you
Old Aug 20, 2002 | 10:11 PM
BigTex's Avatar
Delete step 3 in your instructons. You don't need to wait 5 minutes. Just pull both the fuses, then plug them both back in. Turn car off, then start it up.
Blue03sss
Mar 7, 2019 05:06 PM
AkSSS
Aug 31, 2015 03:24 PM
bjamick
Aug 5, 2015 10:51 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
chvy=power
Jul 27, 2015 10:06 AM
