posi wearing out??
Old Mar 7, 2003 | 11:42 AM
CashDudeHomie's Avatar
Default Re: posi wearing out??
Hey man, I hope you got the Eaton, because there are rebuild kits for it. But I doubt you would really wear one out fast unless you have a lot of horsepower. The old fart that installed mine said a rebuild kit is about 150 bucks. I expect mine to last at least 150,000 miles or so or I will be pissed.
Old Mar 7, 2003 | 01:59 PM
BigKID's Avatar
Depending on the posi unit you have you can check the preload on it. Jack one wheel up, use a torque wrench and see how much torque it takes to turn the wheel. Different preloaded lockers have different values here. I know Auburn has a spec sheet on their page.
As for preventative, make sure you are using the specified fluid and friction modifier for your unit.
kainzien
Nov 10, 2023 11:37 AM
turbo6c3
Oct 5, 2015 06:11 PM
bluebommer07
Sep 20, 2015 08:42 PM
lsxperformance
Sep 14, 2015 10:53 AM
