posi.,4.10,8hr install,went slower.*&^%$#@
Old Apr 13, 2002 | 09:30 AM
Default posi.,4.10,8hr install,went slower.*&^%$#@
I spent 2 days installing an auburn l/s & richmond 4.10 r&p. It's hookin' but it ain't bookin'? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 13, 2002 | 11:36 AM
Default Re: posi.,4.10,8hr install,went slower.*&^%$#@
I was expecting early improvement,but my 60' 330'& 1/8 times up .15 sec.It hooks good with 28/25 rear psi but boggs.The 4.10/1 should have helped. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> I know it pulls my horse trailer better,does chevy have some sort of tq.limiter programed in it that my hypertech programer will not effect? Has anyone else had this problem?
The reason the install kicked my butt was the bearings that came in my auburn kit were a little to small, it was the third time in to set the (lashthatkeptchanging)that we noticed the bearing was allowing movement. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> We went with stock size bearings and all went well.
Am I wrong in thinking it sould be quicker? It looks to me like the 3.42/1 set-up shifting into third just passed the 1/4 line is the best.
any good advise welcome. Even bad advise might be considered. Thanks,Jim
Old Apr 14, 2002 | 12:14 AM
BigTex's Avatar
I am not sure about your times. I would think that the gearing alone would help you get off the line. That is the hardest thing to do with these trucks anyway.
Old Apr 15, 2002 | 07:00 PM
How good are the tires hooking? Try raising the launch RPM. Sounds like you are bogging off the line.
Old Apr 17, 2002 | 08:41 AM
stock generals. Raised tire psi to 32/30 dropped
spare tire, adjusted shift points. ran better.
Dan Neumann
11
Aug 7, 2022 09:06 AM
livefast1
Sep 25, 2015 07:31 PM
Cowboy Tom
Jul 21, 2015 10:29 PM
GM-only
Jul 19, 2015 10:48 PM
