Are ported heads worth the money?
Old Jan 10, 2006 | 11:35 AM
slamedboosted&shaved's Avatar
Default Are ported heads worth the money?
i have a 5.3l whippled, z06 cam, Lt's, ory pipe, and i was thinking about getting a set of heads, which stage and what kind of gain can i expect.
thanks
Old Jan 10, 2006 | 06:52 PM
LS1Tech Sponsor
Definaly power is in the heads. A Stage 1 would be plenty for your setup but they would need to be specificly for boost for the best application.
Nate
Old Jan 15, 2006 | 09:48 AM
moregrip's Avatar
what a rush!
thanks
Sure is/are, WCCH is a sponsor and I know he has a nice 5.3 program, he has always treated me right
let us know what you decide to go with
Old Jan 15, 2006 | 10:17 AM
budhayes3's Avatar
PT's Slowest Truck
Here's a link to a recent thread by BBT with some dyno graphs of his gains from some mild Stage I WCCH heads...seems worth it to me
https://www.performancetrucks.net/fo...d.php?t=356706
Old Jan 15, 2006 | 10:36 AM
gonzo 6.2's Avatar
Anyone have before and after RWH dynos of the WCCH heads?
Old Jan 15, 2006 | 12:04 PM
ktmrider's Avatar
Nate
I agree. Make sure you shop for heads specific to blowers or turbos. You will not see the same gains as the NA folks but there will be some. I just posted the same question in the Forced Induction section.
Look for heads with emphasis on exhaust work and smoothed combustion chambers. Avoid shaved deck heads or ones that increase compression ratio, could cause detonation and KR. Stage 1 should do nicely. You could also look for some stock #317 - LQ9 heads, they have a larger combustion chamber, bigger intake valve, and "D" shaped exhaust port that will flow much better. They also bolt right up and have the exact same mounting pattern so the blower will slip right in. You can find them fairly cheap if you look around here or eBay ( about $200-300 if someone needs the cash ). My two cents....
Silveradorst07
Dec 31, 2015 12:04 AM
ntxf
Aug 10, 2015 10:12 PM
sauldgold
Jul 23, 2015 02:15 PM
jmarkway
Jul 18, 2015 09:23 PM
Aboss
Jul 9, 2015 10:28 AM
